How do you create a frame and title block for reuse?
I'm trying to find a way to create a title block sheet once (which I know how to do) and then be able to load it up to use again on a whole new and different drawing (not another sheet, but a whole new project and the drawing for it). I'm not looking to Insert > object either. I need to be able to edit the block. After you draw your frame and tb under Edit > background, how are you supposed to save that as a CATscript file so it will show up in the list of frame/tb's to load like the 2 that are under Insert > Drawing > Frame & Title block pulldown???? Am I saving at the wrong point??? I've tried recording a macro too but that doesn't want to work out right either. When are you supposed to stop recording? Do you record while in 'background' or in 'Working'. Am I supposed to be able to have views on a sheet and then hit 'macro' and drop that recorded frame/tb in??? Can anyone please help?? Thank you in advance.
v5newto
v5newto
RE: How do you create a frame and title block for reuse?
