Thermal contact conductance(TCC)
4
Hello everyone,
Does anyone have experience with calculating thermal contact conductance(TCC) while using conta174.
Please let me know.
Vinay
RE: Thermal contact conductance(TCC)
3
Vinay, what questions did you have specifically?  I've used 174's on many occasions in a thermal surface-to-surface contact analysis.  Here is a little section below that I thought may be helpful from the documentation:
"The conductive heat transfer between two contacting surfaces is defined by
q = TCC X (Tt -Tc)
where:
q: is the heat flux per area.
TCC: is the thermal contact conductance coefficient, having units of HEAT/(TIME * TEMPERATURE) for force-based node-to-surface contact, or units of HEAT/(TIME * TEMPERATURE * AREA) for the traction-based model.
Tt and Tc: are the temperatures of the contact points on the target and contact surfaces.
The TCC value is input through a real constant, which can be made a function of temperature [(Tc + Tt)/2], pressure, time, and location by using the %TABLE% option. TCC has units of heat/(time x area x temp). If contact occurs, a small value of TCC yields a measure amount of imperfect contact and a temperature discontinuity across the interface. For large values of TCC, the resulting temperature discontinuity tends to vanish and perfect thermal contact is approached. When not in contact, however, it is assumed that no heat is transferred across the interface. To model contact conduction between two surfaces where a small gap exists, use KEYOPT(12) = 4 or 5 to define either the “bonded contact” or “no-separation contact” options."
-Brian
Hi Brian,
Thanks for replying. I know the value of q, how do I find the difference in contact/target temperatures (Tt -Tc).
Can you please elabotrate a bit on "The TCC value is input through a real constant, which can be made a function of temperature [(Tc + Tt)/2], pressure, time, and location by using the %TABLE% option."
Again, here I need to find Tt and Tc.
Vinay
Vinay,
Tt and Tc are not something you typically know in most cases.  Apply loads and bc's as one normally would in a thermal analysis, specify the appropriate elements and contact regions,value for TCC, etc and let Ansys do it's thing.  Note that TCC is input as real constant 14 (see below script).  The documentation is just telling you that it can be specified other ways as well.  Here's an example of what your input should look like:
ET,100,TARGE170     !Target Element Type Defined
ET,101,CONTA174     !Contact Element Type Defined
KEYOPT,101,1,2      !DOF set to temperature
KEYOPT,101,5,3      !Adjust Gaps/Penetration
KEYOPT,101,9,1      !Exclude Initial Penetration/Gap
KEYOPT,101,11,1     !Include shell thickness (if shell model, excluded for solids)
KEYOPT,101,12,0     !Standard contact specified
FKN =.1                 !normal stiffness factor
FTOL = .2               !penetration tolerance
ICON = .2            !initial closure factor
CNOF = 1e-6        !offset value assigned to contact surface
TCC = 500/144/3600    !contact conductance value (perfect conduction)
!R1, R2, FKN, FTOLN, ICONT, PINB    !Real 1-6
!PMAX, PMIN, TAUMAX, CNOF, FKOP, FKT    !Real 7-12
!COHE, TCC, FHTG, SBCT,RDVF, FWGT    !Real 13-18
C*** Contact to Target Specification
R,1000,,,FKN,FTOL,ICON,,
RMORE,,,,0,,,
RMORE,,TCC,,,,,
ESEL,NONE $NSEL,NONE     !Unselect all nodes & elements
TYPE,100                 !Specify Target Elements
ESEL $NSEL               !Select Elements of Target Surface
ESURF                    !Mesh target surface
TYPE,101                 !Specify Contact Elements
ESURF                    !Mesh contact surface
Edit this to suit your application...this is just a general format of what a contact macro would look like.
Good luck,
-Brian
Disregard my first post.  Sorry this is a more correct version:
Vinay,
C*** Mesh Target Surface
RMORE,,,,0,,,
RMORE,,TCC,,,,,
ESEL $NSEL               !Select elements and nodes of target surface
C*** Mesh Contact Surface
ESEL $NSEL               !Select elements and nodes of contact surface
Good luck,
-Brian
Thanks Brian,
This helps.
Vinay
Hi Brian:
do have that macro of TCC in GUI format, I mean how to do the commnads from the menu, not from the command line ?
how you can change the KEYOPT ?
thanks
Frank
Frank,
Using the contact wizard is by far the easiest way to make contact via GUI.  As for changing element keyopts that can be done in GUI mode under Preprocessor -> Element Type -> Add/Edit/Delete -> Options.
Good luck,
-Brian
Hi Brain:
Thanks so much for your valuable reply and advice.
Another question, please:
I have two 2D surfaces that have a common line and I need to study the heat transfer from one surface to the other through their common line, so how should I mesh these surfaces and their common line in a way that ANSYS will consider the thermal contact conductance ?
Frank
Frank,
Thermal shell elements are the best choice for something like that.  Check out SHELL 131 and SHELL 132 and determine which one suits your needs best.
-Brian
Hi Brain:
Thanks again for your valuable help and replies.
Now I am able to model the interface conductance at the interface between two areas and I can play with the value of thermal contact conductance to get different results, so now, I am wondering if I do NOT define the contact pair at the interface, and let the ANSYS solves the model, what is the default of ANSYS in dealing with the interface ? does it consider it as a perfect contact (very high value of thermal conductance) or perfect thermal resistance (very low value of thermal conductance) ?
Frank
If you have a continuous mesh why would you need to consider any sort of contact there?  If your mesh is not continuous then of course you'll need contact to bridge the gap.
Hi Brain:
Are you saying if we have a nice continuous meshing at the interface of two areas, we do not need to define a contact pair ? ...well so what is the importance of having such function of creating a contact pair ?
I agree with you that if the mesh is not continuous at the interface, you will have an artificial gap and it will hurt the solution.
hi guys:
what should i do when I get a error message saying "unconstrained model" when trying to solve thermal analysis steady state case ?
thanks
hi all:
is there a way to undo or cancel the command of "Merge" ?
Frank
No. This is a general rule in Ansys (no "undo" feature). But you can export the log file of your session and then edit it in order to eliminate the last operation of "merge", then read it in again.
hi,
Thanks so much "cbrn"....it works...wow..you saved my day !
best regards
Frank
