Brinell Hrdness Number
Hi friend,
can anybody explain me... if a metrial having a brinell harnbess number of 197 and another material having brinell hardness number of 187...
how to determine which material is strong... i mean which material will be going to have more ultimate tensile strength
RE: Brinell Hrdness Number
If they are not the same type of alloy or they were not made the same way then it only means that they have different BHN values.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
We perform Portable Brinel Hardness testing (Using Tele Brinel equipment), this is using Hammer and indentation method.
This being a field test to checking the Gross quality, to check whether the material after fabrication complies to specification that calls for 197 Brinel (3000 Kg), What load should we consider for Telebrinel?
