Non-circular holes in the SW Hole Table
Is it possible to automatically turn off non-circular holes in the SW Hole Table?
RE: Non-circular holes in the SW Hole Table
I don't believe there is, but you may be able to create an API macro which traverses the drawing view (or table) to find & then delete them from the table. Others here may be able to help you with that.
If you used the face to select all the holes, you will need to individually deselect the non-circular ones.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
If there are not too many non-circular holes, the simplest way would be too just delete the rows from the Hole Table.
An automatic exclusion option could be useful though. Send in an ER.
cheers
