Minimum Material Bend Radius
I'm trying to find a reliable resource for minimum bend radius for various materials. I'm currently working on a problem of a 2024-T3 formed sheet metal panel that is cracking at one of the panel edges. The panel isn't heavily loaded and it is in a relatively low vibration environment, so I was initially perplexed. I started to review the drawing and the sheet thickness is .04" and the bend radius are .12". So, looking at my old reliable design slide rule I noticed that the minimum bend radius for the above material is .25". Running this question by another designer, and his slide rule has the minimum bend radius at .12". I couldn't find anything in the Machinery HNDBK 26, so I was wondering if someone else had another resource.
RE: Minimum Material Bend Radius
