30 NCD 16 Alternative Spec
Hello All
I am trying to find an alternative steel specification to replace the french 30NCD16 called up on a drawing. Do any of you know of any? The part to manuafactured from the material is a small collar.
Many thanks!
Zak
RE: 30 NCD 16 Alternative Spec
You have not provided nearly enough information for anyone to provide a meaningful answer.  What is the size of the part?  What are the requirements for final mechanical properties?  What is the potential failure mode (wear, fatigue, corrosion, fracture, etc.)?  Why do you need a different grade?  Is it due to lack of availability in North America?
This is a Ni, Cr, Mo steel with 0.25-0.35C.
What product form and properties are you after?  There are a lot of similar grades.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
