Turbulent mixing in an entrainment device.
I am looking for information on the following area: any info or references would be appreciated.
In a nozzle - diffuser arrangement with a mixing chamber in-between, how can any losses in entrainment caused by increasing backpressure originating downstream of the diffuser, be minimised.
RE: Turbulent mixing in an entrainment device.
I can suggest two things that may or may not be applicable, since I don't know the specifics of the system you're working on. First, could the system be placed under a vacuum if it isn't already? If not the whole system, maybe just the part downstream that is creating the backpressure. Secondly, what about a vent valve downstream of the diffuser...it could be used in conjunction with a pressure sensor to automatically open and bleed off pressure to some type of tank, or atmosphere if the system is non-toxic, etc...
In your system the mixing ratio is a bit degraded with the backpressure. Therefore your primary variable is time or larger volume.
If you installed a tank or a fat section of pipe downstream of your device you would obtain better mixing. You might You might also consider positioning the nozzle in the tank or fat section of pipe such that you will get recirculation. You could look into jet tank mixers (Penberty?) to get an ideal of the spacial dimensions and mixing ratios you might expect.
Good Luck, let me know if I have missed your boat here.
