plot in gui
plot in gui
is there any way i could make this program plot my own functions? e.g. x^2 + 3x ... i think something like changing the listbox in function chooser to en edit box? any suggestions?
function GUIdemo(fcn)
%demo of user interface construction
%this function CALLS ITSELF via GUI callbacks
% By default make the GUI
%This code detects the first entry into the function
%from the command line with no parameters
if nargin == 0
fcn = 'makeGUI';
end
%This is the main decision point of the function.
%The switch statement is executed once-per-fuction call
switch fcn
%This code is executed ONCE when the function enters with
%no arguments
case 'makeGUI'
% Determine the name of this function and store it in the
%figure plotinfo variable.
%Since variables used in a function are not persistent after
%the function exits we will need to store the state-variables
%in a data structure associated with the persistent Figure-window.
%The plotinfo sturcture will be saved into the Figure's UserData
%area and retrieved from there as necessary.
plotinfo.myname = mfilename;
% ===Create main figure==========================
fig = figure('Position',centerfig(660,630),...
'Resize','off',...
'NumberTitle','off',...
'Name','GUI demo',...
'Interruptible','off',...
'Menubar','none',...
'Color',get(0,'DefaultUIControlBackgroundColor'));
%===Header text===================================
uicontrol(gcf,'Style','text', ...
'String','A GUI example',...
'fontsize',20, ...
'HorizontalAlignment','Center',...
'Position',[200,600,220,30],...
'BackgroundColor',[0.8 1 0.8]);
%===A menu======================================
cmenu=uimenu(gcf,'label','figure color');
uimenu(cmenu,...
'label','grey',...
'callback','set(gcf,''color'',''default'')');
uimenu(cmenu,...
'label','yellow',...
'callback','set(gcf,''color'',''yellow'')');
uimenu(cmenu,...
'label','black',...
'callback','set(gcf,''color'',''black'')');
% ===Create axes=================================
plotinfo.ax = axes('Units','pixels',...
'Position',[235 165 395 360],...
'Box','on',...
'XLim',[0 1],'YLim',[-1 1]);
xlabel('x'); ylabel('y');
% ===The quit button===============================
uicontrol('Style','pushbutton',...
'Position',[595 595 45 25],...
'String','Quit',...
'BusyAction','cancel',...
'Callback',[plotinfo.myname,' quit']);
%==Frequency slider===========================
plotinfo.freq=1.0;
plotinfo.s1 = uicontrol(gcf,'Style','text', ...
'String','frequency',...
'Position',[10,240,100,20],...
'BackgroundColor',[0.8,0.8,0.8]);
plotinfo.s2 = uicontrol(gcf,'Style','edit',...
'String',num2str(plotinfo.freq),...
'Position',[110,240,50,20],...
'BackgroundColor',[0.8,0.8,0.8],...
'callback', [plotinfo.myname,' editfreq']);
plotinfo.s3 = uicontrol(gcf,...
'Style','slider',...
'Min' ,1,'Max',20, ...
'Position',[10,220,150,20], ...
'Value', 1,...
'SliderStep',[0.01 0.1], ...
'CallBack', [plotinfo.myname,' setfreq']);
%==Draw button===========================
uicontrol(gcf,'Style','Pushbutton', ...
'String','Draw',...
'Position',[10,450,70,20],...
'BackgroundColor',[1,0.8,0.8], ...
'CallBack',[plotinfo.myname,' draw'] );
%==Function Chooser=========================
plotinfo.fun='sin';
plotinfo.choose=uicontrol(gcf,'Style','listbox', ...
'String','sin|cos|tan',...
'Position',[10,390,70,50],...
'BackgroundColor',[0.8,0.8,0.8], ...
'CallBack',[plotinfo.myname,' choose'] );
%==Open a dialog box========================
uicontrol('style','text',...
'string','Dialog box chooser',...
'backgroundcolor',[.8,.8,.9],...
'position',[10,40,70,50]);
plotinfo.dlg='1';
plotinfo.number{1}=' no number yet!';
plotinfo.dlgbox=uicontrol(gcf,'Style','popup', ...
'String','error|help|input|msgbox|question',...
'Position',[10,10,70,50],...
'BackgroundColor',[0.8,0.8,1], ...
'CallBack',[plotinfo.myname,' dialog'] );
%==radiobutton===================================
plotinfo.red=0;
plotinfo.rbut=uicontrol(gcf,'Style','checkbox', ...
'String','Red axes',...
'Position',[10,300,70,50],...
'BackgroundColor',[1,1,.8], ...
'CallBack',[plotinfo.myname,' redaxes'] );
%==axes title====================================
plotinfo.title='Use edit field to change this title';
plotinfo.ttl=uicontrol(gcf,'Style','edit', ...
'String','Edit Figure title',...
'Position',[10,130,150,20],...
'BackgroundColor',[1,1,1], ...
'CallBack',[plotinfo.myname,' edttl'] );
%==Context sensitive menu==========================
%====Also note reference to this menu in the plot==
% Define the context menu (taken from Matlab docs)
plotinfo.cmenu = uicontextmenu;
% Define the context menu items
plotinfo.item1 = uimenu(plotinfo.cmenu, 'Label', 'dashed', ...
'Callback',[plotinfo.myname,' linemenu1']) ;
plotinfo.item2 = uimenu(plotinfo.cmenu, 'Label', 'dotted', ...
'Callback', [plotinfo.myname,' linemenu2']);
plotinfo.item3 = uimenu(plotinfo.cmenu, 'Label', 'solid',...
'Callback', [plotinfo.myname,' linemenu3']);
'string','Hit Draw button, then right-click the plot line for options',...
'backgroundcolor','white',...
'position',[350,100,150,40]);
%put all the variables in a safe place (the figure's data area)
set(fig,'UserData',plotinfo);
case 'draw'
x=0:0.001:1;
amp=1.0;
%Get data from the figure's data area
plotinfo=get(gcf,'UserData');
y=eval(strcat(plotinfo.fun,'(2*pi*plotinfo.freq*x)*amp'));
plotinfo.line=plot(x,y,'black',....
'uicontextmenu',plotinfo.cmenu);
set(plotinfo.rbut,'value',0);
title(plotinfo.title);
set(gcf,'UserData',plotinfo);
case 'quit'
fig = gcf;
quit_reply = questdlg('Really quit this lame example?');
if strcmp(quit_reply,'Yes')
close(fig);
end
case 'setfreq'
%Get the value from the slider
plotinfo.freq=get(plotinfo.s3,'Value');
%Update the text which shows the slider value
set(plotinfo.s2,'String',plotinfo.freq);
%Store the new slider value back into the figure's data area
case 'editfreq'
plotinfo.freq=str2num(get(plotinfo.s2,'string'));
set(plotinfo.s3,'value',plotinfo.freq);
case 'choose'
plotinfo.fun=get(plotinfo.choose,'value');
switch plotinfo.fun
case 1
plotinfo.fun='sin';
case 2
plotinfo.fun='cos';
case 3
plotinfo.fun='tan';
end
case 'dialog'
plotinfo.dlg=get(plotinfo.dlgbox,'value');
switch plotinfo.dlg
case 1
errordlg('Ouch!, now you''ve done it!');
case 2
helpdlg('Feel the Force, Luke.');
case 3
plotinfo.number=inputdlg('Enter a number');
case 4
msgbox(strcat...
('The last number you input was ',...
plotinfo.number{1}));
case 5
questdlg('Have you called your mom lately?');
end
case 'redaxes'
plotinfo.red=get(plotinfo.rbut,'Value');
if plotinfo.red
set(gca,'color','red');
else
set(gca,'color','white');
end
case 'edttl'
plotinfo.title=get(plotinfo.ttl,'string');
case 'linemenu1'
set(plotinfo.line, 'LineStyle', '--')
case 'linemenu2'
set(plotinfo.line, 'LineStyle', ':')
case 'linemenu3'
set(plotinfo.line, 'LineStyle', '-')
end
%===A utility to center the window on the screen============
function pos = centerfig(width,height)
% Find the screen size in pixels
screen_s = get(0,'ScreenSize');
pos = [screen_s(3)/2 - width/2, screen_s(4)/2 - height/2, width, height];
if nargin == 0
fcn = 'makeGUI';
end
switch fcn
%no arguments
case 'makeGUI'
'Resize','off',...
'fontsize',20, ...
uimenu(cmenu,...
'label','grey',...
uimenu(cmenu,...
uimenu(cmenu,...
'label','black',...
'Box','on',...
'String','Quit',...
plotinfo.freq=1.0;
'Value', 1,...
'String','Draw',...
plotinfo.fun='sin';
plotinfo.dlg='1';
plotinfo.red=0;
case 'draw'
x=0:0.001:1;
amp=1.0;
case 'quit'
fig = gcf;
close(fig);
end
case 'setfreq'
case 'editfreq'
case 'choose'
switch plotinfo.fun
case 1
plotinfo.fun='sin';
case 2
plotinfo.fun='cos';
case 3
plotinfo.fun='tan';
end
case 'dialog'
switch plotinfo.dlg
case 1
case 2
case 3
case 4
msgbox(strcat...
case 5
end
case 'redaxes'
if plotinfo.red
else
end
case 'edttl'
case 'linemenu1'
case 'linemenu2'
case 'linemenu3'
end
RE: plot in gui
What you might need to add ar boxes which will define plot variable, limits and other parameters, and then put then all into a matlab compatible string, and let matlab do the hard work.
