Heavies conditioning for gasification
I started a work identifying three different "streams" of oily residuals that can be theorically conditioned by blending and make amenable as feedstock for a pilot gasifier, whose output must be syngas for electricity.
Let me know what You guys think of the following:
1) Traditional Bottom Of The Barrel Streams composed of visbroken tar, heavy vacuum gasoil (HVGO), petcoke and heavy cycle oil (HCO).
2) Slurries: tank bottom sludge, other refinery residues including bitumen heavies, non classified distillation residues and organic wastes
3) Post-consumer spent lube oils, metalworking hydraulic fluids and oily emulsions
The main driver for such selection of feeds is the chemistry of these streams which allows for the co-production of asphalt and bitumen grades, thus rising the overall attractivity of the project if any.
Just admit for a moment that it is economically convenient to collect, transport and condition off-site and outside battery limits these streams separately, what do You think are the most challenging or less feasible features of waste-to-fuel conditioning of such a mix of wastes? Should I take into account severe thermal cracking or can I rely on mild reprocessing and some sort of blending?
Please consider we are in Italy and not in Canada! (I mean we would have never considered this if we had all those oil sands bitumen reserves available!)
I m here online to give You any other detailed information.
RE: Heavies conditioning for gasification
PB500,
Your major gasification problem will be formation of tars and plugging.
For more information see:
www.plasmawhirl.com
Todd
www.oxilume.com
Ok. Now I keep them slurries, pumpable, so I eliminate the emulsified oils extracted from spent lubricants, I do not trust their performance once decoupled from their mixed formulated bonds. The problem is transferred down the pipeline to the nozzles and reactor lining; combustion is meant to solve it. Thanks very much
