Requirements for Tantalum Tube Testing for Heat exchanger
Hello Reader,
I am buying Heat exchanger with Tantalum Tubes(B521-UNS R05252).
Can somebody please guide me what are the Testing requirements for the Tantalum Tubes.
I would appreciate quick responce.
Mechmania
Mechmania
RE: Requirements for Tantalum Tube Testing for Heat exchanger
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Yes,Testing requirement after installing tube to the unit.
Do we have to inspect the individual tube after the tube is attached to tube sheet?
Do we have to specify any special requirements in fabrication of Ta tube to Tube sheet Joint?
Do we have to perform any other test than He Leak test?
Yes the service is corrosive on tube side. My special concern is beacause tube is only 0.015in thick
And also,Is it ok to rolled and expand 0.015in thick tube to tube sheet?
Looking forward for more guidance.
Thanks.
Mechmania
No. How are the Ta tubes attached to the tubesheet? If they are rolled or expanded and seal welded - Liquid PT. If the tubes are rolled with no welding, a He leak check is fine.
