DIVIDING A PART TO SHELL ONLY CERTAIN SECTIONS
I have a part which I split in half. I'd like to shell each half. Each section has some thin cross sections which I know will prevent the part from being shelled. I'm wondering if there's a way to just shell certain sections (bypassing the thin walled cross sections, excluding from the shell those thin walled sections)?
Thanks.
Thanks.
RE: DIVIDING A PART TO SHELL ONLY CERTAIN SECTIONS
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
Another thing you might try is a multi-thickness shell.
Also, you might just try it. The shell works much better than it used to.
