falling-film heat exchanger
There is a type of heat exchanger, patented in 1985, where (on one side at least) the fluid falls down the surface in a film under the action of gravity.  ie that side of the heat exchanger is not full of fluid.
Does anyone know of examples of this principle in prior art?
Thanks in anticipation,
M Rutherford
RE: falling-film heat exchanger
Hi mattatdeneb,
Fallling film heat exchangers or evaporators are long known in the process industries,used to concentrate or separate heat sensitive materials.. to name but a few..  check(www.luwa.com) and (www.alfalaval.com)..
Whylie
