fastener tension results from multiple layers
Supposing to have 3 fem/quad layers and a 2 allined cbar simulating fasteners crossing them.I'm in doubt about tension element results if summing (supposing 3 layers)the 2 bar element forces is as to say having resultant tension acting force on bolt....it seems to me that single element can give by themself a relative reading on the stiffness of the 2 remaining layers from each side so that both from their side can give a real tension acting load....so that the maximum tension results from these 2 forces can be considered to verify the bolt.
Is it true? Can give this question some doubt? How to approach correctly this question?
RE: fastener tension results from multiple layers
...and for shear resultant on bolt?always in multiple layer configuration. thank you in advance.
