part inspection tools
I am looking for a reliable & repeatable method/tool to measure a radius on a pipe. In our application we are making oilfield equipment that consists of a pipe with an "upset" (larger diameter section on an offset centerline). The radius (4" to 8" radius) we are trying to measure begins tangent with the pipe OD and ends tangent on a transition angle to the larger OD.
I found this
http://www.arcmaster.ca/
but don't know if we can pass calibration/certification standards for use. Any recommendations would be appreciated.
Louis
I found this
Louis
RE: part inspection tools
Can you cut a section from the pipe and put on an Optical Comparator, those are reliable & repeatable and have been in use for decades.
CODE
Business Card http://mech.e.tripod.com
__________________________________________
Cycle Heaven.......www.tailofthedragon.com
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
