Forming Tool config. (louver)
I think I already know the answer, but.....is it possible
to switch between configs of a form tool after insertion?
RE: Forming Tool config. (louver)
Unfortunately you cannot edit the configuration of the forming tool once you place it on your part. The only time you can choose a configuration is when placing it in your model. You will have to delete the forming tool feature and re-insert the configuartion of the one you want. This would be a good ER to submit. I know I'm going submit one for this issue today.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP0.0
GB,
That option is seems to be unavailable for forming tools.
All I can figure is to open the louver and save to the
desired config before insertion.
My bad...misunderstood that application and am probably not smart enough to have answered anyway 2thumbsup
GB...every little bit helps... ;o)
JK, is there supposed to be a prompt for a config before insertion...???
Actually I got mixed up. I don't think forming tools can have configurations. I will check this out after a meeting I have right now. I know that the configurations work for features and design library parts. Talk to you in a few...
Best Regards,
Jon
You should be able to make configs of the part. Each config varying the feature dims of the Louvre ... same as any other feature.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
You don't have to delete the forming tool feature, just supress it and create a different config of a different forming tool.  But you would have to insert different tools for as many configs as you want.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
After trying several times forming tools do not allow configurations. Only Design library features can have configurations in which you can select if they are available. Submit an ER to solidworks. If enough of us request this it may get put into a future release.
Best Regards,
Jon
