Solidworks Simulation
Does anyone know if Cosmos motion or any other solid works add-in can simulate motion based on a path created by sketch lines, or possibly even the interpolation of a set of sketch points?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Solidworks Simulation
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
http://w
He has some good examples of thing you can do is SWKS animation.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Create a single point in a 3-d sketch and mate the robot tool to that point. Then us a design table to create configurations which move the point through your working volume. Then you can switch between configs to move the robot, and check joint angles against the ranges of motion. Some VB code may be warranted, if the number of points is large, or you plan on doing this a lot.
Seems kind of clunky, but it might work.
Eric
