Pig Trap and Pig Launcher Package Suppliers
4
I need contacts details for Pig Trap and Pig Launcher Package Suppliers - Could anyone please assist by sending me information on reliable companies for these items?
RE: Pig Trap and Pig Launcher Package Suppliers
Taylor Forge in Kansas furnished launchers and receivers on a project a few years ago.  Search for the closure that you prefer and specify it before you issue the inquiry.  Assure that you define compatible and incompatible o-ring material too.  When the closure o-ring material furnished by Taylor Forge was determined to be incompatible with the sour gas, Taylor would not replace the o-ring on their nickel.  This is a very large o-ring the cercumference of the closure.
The TDW launcher is pretty cool (I especially like the closure on the big-inch equipment).  I would use a launcher for both launching and receiving since the bypass is too close to the barrel-isolation valve on the receiver.
David
Could anyone kindly share descriptive list of components and accessories for a typical pig launcher and receiver?
Take a look at my web site under "Samples", there is a document called "Rules of Thumb for Gathering System Equipment" that has descriptions of all the components of a launcher and receiver.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
