Properties of 8630mod. Steel
I am looking for anybody that may be able to tell me or point me in the right direction of finding the allowable stresses of 8630 mod. steel at room temperature and at an elevated temperature of 100 Degrees c.
RE: Properties of 8630mod. Steel
Regarding the modified version, I have seen this stated from various suppliers and the difference between 8630 and 8630 mod are slight variations in chemical composition in terms of Mn (slightly higher min/max than the standard min/max range for 8630), lower P and S contents, slightly higher min/max range for Cr, Ni and Mo. Overall, the modification to the standard alloy seems to increase hardenability.
