obtaining force/displacement values?
Hi all,
im currently involved in the redesign of a major component at our plant and am required to gather data on the forces acting on the machinery.
the piece of equiptment is a roller which is pneumatically powered to rise and lift a sheet and then fall via quick exhaust acting as a quick outlet for the pressure.
im aiming to calculate the bending moment and shear stress acting on the clevis brackets holding the roll in place.
any ideas on how i can obtain some acceleration, force values using instrumentation?
regards
regards
RE: obtaining force/displacement values?
If you want to get displacement directly, then you could attach an LVDT to the base/cylinder and roller/piston.
If you are going to use an Accelerometer, make sure its a DC Accelerometer - then you can integrate to get velocity and displacement.
Finally, how about monitoring the air pressure throughout the cycle - a poor second to the load cell.
For all this you should acquire data at something like a kilohertz - as a guess, not knowing your system in any detail.
I agree to MintJulep and solider.
If not, is there a particular part of the cycle you are concerned with?
what data will the accelorometer actually display?
For the block, the mass (m) is the weight divided by the acceleration due to gravity (g).
For the spring F = kx.
And by Newton's 2nd F = ma . . . so ma = kx, and a = kx/m.
Mount the potentiometer on the bracket, the spring on the potentiometer shaft and the block on top of the spring.
Each time the roller falls, the potentiometer will record a max displacement (x).
From this you'll get acceleration without spending a fortune for equipment that won't be used long term.
Cheers
Greg Locock
