Remove intersected body parts
I created a simple extrusion and an extruded cut inside it., then I created an off center and tilted axis and made a circular pattern out of them:
Now I want to remove all the intersections inside the new formed body, keeping only the new formed perimeter.
How can I do this in SW2006?
RE: Remove intersected body parts
Have you looked into the combine feature?
I will look into it more tomorrow.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
The simplest way is probably to offset your outer surfaces to a thickness of zero.  Delete the solid body.  Thicken your offset surface.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
How about deleting the extruded cut, keeping the pattern and shelling?
A star for dgowans.  I think he's got the solution with the lowest feature count.
Another alternative is to pattern the inside surface and trim the solid before patterning it.
-b
If the axis of rotation is offset & tilted, a circular pattern would create a non-uniform perimeter thickness ... no matter what shapes the base and cut extrusions were.
The Combine function would be the simplest method.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
The product you created does not have a flat top or bottom, and I don't know if you will leave them like that, or will add another step to cut them flat. If they are supposed to be flat, then a loft would work.  Loft then shell.
 http://livedigital.com/content/441099/u86412
Flores
SW06 SP4.1
