Eye bolt vs. Lifting lug
Is it better to use a eye bolt or a lifting lug? I have a 30 mm thick plate(ss)thats going to be bolted(6 bolts- 16mm) on a 1000 lb pump. Can I use either a eye bolt on this plate or weld a lifting lug on the middle of plate to lift this pump? If I use a lifting lug, whats the minimum thickness of the weld around the base of the lifting lug? Is there a load chart for lifting lugs like the one for eye bolt? Are the 16 mm bolts being used to mount this plate on the pump going to be ok under the 1000 lbs of tension load ?
RE: Eye bolt vs. Lifting lug
I personally like to use the bolted swivel safety type.
http://www.americandrillbushing.com/fastloksys.htm
