new UL 508A KAIC ruling
Does someone on this board know about the newly effective KAIC rating of components inside of UL 508A panels?
Our problem is the unrated solid state relays are now only rated for 5 KAIC. Accordingly, the newly effective UL 508A rules imply 5 KAIC is the rating of the panel with these relays. Of course our customers need 10, 15, 22, 35, and 65 KAIC rated panels.
What's the solution to our problem?
TYIA,
Heaterguy
TYIA,
Heaterguy
RE: new UL 508A KAIC ruling
If that doesn't work, then you need a SS relay listed with higher fault ratings. It could be a ss relay that provides a higher fault rating when protected by a manufacturer recommended means.
