Broken View on Drawing question
I have a broken view on a drawing and I was wondering if it is possible to create the isometric shown as a broken view as well. Basically you would see the inside of the pipe after breaking it. I have included a link to the picture for your reference.
Thanks in advance,
Bloodclot
http:/ /img70.ima geshack.us /img70/104 6/imagesha ck17pw.jpg
Thanks in advance,
Bloodclot
http:/
I come from a small town where the population NEVER changed. Everytime someone got pregnant, someone left town.
RE: Broken View on Drawing question
If you turn one in also, maybe it can get fixed.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Bloodclot
What do you see when the Pillsbury Dough Boy bends over?
Doughnuts
What are you trying to achieve in the isometriclly broken view that you could not show in a section view or broken out view? You can add a break to the isometric view but you are not going to get your desired results of seeing inside the pipe.
Breaking the view is just that, it only breaks what is shown in the view and spaces it apart at a specified distance, it does not actually make a physical cut in the part like you want to achieve. The only solution is to do as I have suggested above.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP0.0
As for the "common" ER threaad, it has been suggested before but never took off. Probably because it turned into a bitching thread instead and because not everyone wants the same thing when it comes to ERs. e.g. I would not submit an ER for the above, because it might take away resources from other more important (to me) ERs.
But there are a lot of new members, so maybe it will work this time.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
CorBlimeyLimey - I understand your point about resources. However, no matter what the ER issue is, SW will ultimately prioritize and decide which ER's will be implemented. At least if everyone throws their ER's in one place we can all pick and choose which ones to follow with ER's of our own. Example, if you sent in an ER for something that I have not come across yet but I feel it would help me to have that functionality in SW, I would be more than willing to send in an ER for the same issue with the hopes that by the time I need that functionality it may be implemented. My 0.02.
Bloodclot
Doughnuts
