Block name
Block name
Block name
I'm using the command
add_block('simulink/Sinks/Out1','sys/pippo/output_name');
to insert a the sink Out1 in the object pippo in the model sys. The name of Out1 in pippo is output_name.
I have a char variable that contains the name of the Out1 I want to insert in pippo. Does exist a command to insert an object (like Out1) in pippo, assigning to the object the name contained in a char variable?
Thanks!
