3D sketch - move?
3D sketch - move?
I have a 3D sketch that was created off of imported IGES curves (I was not the original modeler). The 3D sketch is undefines (i.e. blue). I want to translate (or move in SW term). This does not seem possible with 3D sketches. Is this true? The Tools\Sketch Tools\Move command is blanked out. What I would like to do is move all the entities in the sketch as a whole a certain distance away from the origin. Any thoughts? Heck I would mind moving the origin if that is the case.
oharag
oharag
RE: 3D sketch - move?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
2. Select everything in the sketch
3. Hold crtl button down
4. select the point in the sketch you want to move, and start to drag
5. let go of ctrl button
6. continue dragging and drop on point in step 1.
Jeff Mowry
