drafting methods
drafting methods
is it okay to dimension section views.
RE: drafting methods
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Yes!
Ok that's the short version.
I prefer sections to use of hidden line most of the time, I thought it was in a standard somewhere that sections etc are preferable but I couldn't find it last time I looked.
aardvarkdw,
I'm with you on ISO views but in my post the other day people seemed to think 14.41 might allow this.
Ken
Wes C.
When they broke open molecules, they found they were only stuffed with atoms. But when they broke open atoms, they found them stuffed with explosions...
You only need another view if needed.
Chris
AutoCAD 06
Chris
AutoCAD 06
On the hidden in Y14.5, thanks ewh don't know why I couldn't find that the other day.
Ken
Was he requiring three views or just as many views as nessesary?
ewh,
I agree there are times when dimensions are allowable in iso or axo views as with ASME y14.41 but that I believe refers only to 3d models not to 2d drawings. I may be wrong on that, as I've mentioned in other threads I am still working on getting a copy of the y14 series here.
Only 3 views. But, doesn't matter anyway, all views are the same.
Chris
AutoCAD 06
Chris
AutoCAD 06
Out of interest could one of those views be an iso?
Chris
AutoCAD 06
Now, to a lot of new drafters, that's getting into too much science and physics.
Chris
AutoCAD 06
iT'S THE RULE.
CHeck out the ASME standards. There are certain scales to use. You do not want to use for example 1.25:1 or 23:1.
Chris
AutoCAD 06
ctopher's home (updated 06-21-06)
ctophers advice about the standards would go for a couple of the questions you've asked.
I'm sure most of us are more than happy to answer questions but if you get a chance to look at the standards that will answer not just your immediate question but maybe tomorrows as well.
