Square graph in excel?
Is there any way to force excel to draw the X and Y axes at the same scale?
RE: Square graph in excel?
Insert the following:
Selection.Width = 450
Selection.Height = 450
Select the chart
run the macro
TTFN
TTFN
For example if I plot y=x it would be 45 degree from horizontal with 1:1 aspect ratio.
But if X axis is 0-10 and Y axis is 0-100, then a plot of Y=X will be about 10 degrees from horizontal.
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
Wm. Phelps Eno, ca. 1928
There was a vba solution I posted in the linked thread 3 Dec 05 which met my needs very well (one execuation of the macro auto-scales and sets 1:1). It was based on another posters information prior to that in the thread. Subsequent modification was made but I don’t know what it did.
Also at the end of the thread, Yakpol had a suggestion for creating a phantom series that when autoscaled would accomplish the same thing. I never tried it.
