Hole Wizard shared sketch
Is it possible to have multiple hole wizard features share the same sketch... when you add or delete sketch points all hole wizard features referencing that sketch will update.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Hole Wizard shared sketch
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Chris
AutoCAD 06
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
If this is what you are trying to do you are SOL.
The points used to define the subsequent HW sets will still exist if you delete a point from the master sketch and will not be automatically created (i.e. not exist) if you add points to it.
I'm not sure it's possible, but you may be able to use the master sketch in a "Sketch Driven Pattern" so that all the points are used & then use a DT to "Skip" the uneeded holes.
As ctopher & Gildashard have suggested, the simplest way is to use a separate sketch pattern for each HW set.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Ken
Jason
Chris
AutoCAD 06
