Hole Wizard Countersunk Hole *Not* ANSI
I have been trying to find the ANSI standards for metric countersunk hole dimensions. The only place I've found on the Internet is:
http:// www.a-sp.o rg/Standar ds/chapter s/assembly /F1-23.pdf
The values there correspond to the results we've been seeing here...if the holes are machined according to the default ANSI values in the Hole Wizard, then the Flat Head screws will not mount flush.
Can anyone out there verify this for me, or correct me if I'm wrong? For now I'm going to go into the Hole Wizard database and modify the hole sizes there.
Ken
http://
Ken
RE: Hole Wizard Countersunk Hole *Not* ANSI
Then again, hopefully no-one else modified your database.
Flores
SW06 SP4.1
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
It looks like you have to overdrill the countersink depth to get a flush fit.
I just created a countersunk hole in Wildfire2 and its depth is 2.11, with a top dia of 6.72, whcih matches the specs.
Ben Loosli
Sr IS Technologist
L-3 Communications
I could not find ANSI standards for metric FHCS holes in Machinery's Handbook.
Comparing the SW Hole Wizard countersunk large diameter, to the hole values at the website I mentioned above and the fastener dimensions in Unbrako...will result in every size above M4 not being a flush mount.
Our internal cross-reference table in Excel used by our AutoCAD system has values for FHCS holes and those values went along with what I found at that website, not with what is in SW Hole Wizard.
I'm not sure if this is a Hole Size or a Fastener Size issue (not being in spec. with ANSI), but something is definitely not right.
Ken
