Catia V4 Views
Catia V4 Views
When I use Auxview2 and try to delete a view, it says that it can't. It won't delete with regular Auxview either. I've done Erase/Pack and /cln, with no luck.
Any help that anyone can give me would be greatly appreciated. :)
RE: Catia V4 Views
Is the unwanted view a parent to another view?
RE: Catia V4 Views
The view is the remaining view of 2 views of a detail.
RE: Catia V4 Views
RE: Catia V4 Views
RE: Catia V4 Views
If that is not the case there maybe a rule or attribute tied to it, these will have to be deleted to delete the view...
Do an identify + list to see all that is there.
I need some help here from the V4 guys as I have not been on it for over a year.
Cheers
RE: Catia V4 Views
RE: Catia V4 Views
yes : one view is a minimum in a draft.
RE: Catia V4 Views
I have a single draft, with many views in it, and there are only a few views of which that I want to delete. It's the views that I want to delete that I'm having problems with. For example, I had a plan, side, and front view of a detail. It would let me delete the plan view, but not the other two.
RE: Catia V4 Views
RE: Catia V4 Views
RE: Catia V4 Views
RE: Catia V4 Views
If you delete section a-a then you can delete your plan view.
The views that you are not allowed to delete are somehow related to the creation of another view that still exists.
RE: Catia V4 Views
RE: Catia V4 Views
