Renaming all parts and drawings in assembly at once
My company has a unique work order for each job, and we are often retrieving old work orders renaming all parts, assy's, sub-assy's, and drawings. We are currently using SW explorer to rename our assemblies and parts, and a batch file renamer to rename drawings.
We don't have many problems using this method, it's just that it would be nice if we could simply replace all old work-order #'s in filenames with new work-order #'s in one step instead of renaming each component individually. Are there any macros out there that could rename mutiple part files in a batch while keeping part and drawing references?
The closest thread I could find was: thread559-133945.
Thanks in advance for your help.
RE: Renaming all parts and drawings in assembly at once
The problem is you can't replace file names with new text, for example the first 6 characters with the new project number.
So the answer probably is no, there isn't a quick way of doing this because you would still have to use SW Explorer to rename each part.
On a side note, if we use an existing part/assembly for a new project, we keep the same file name.
Flores
SW06 SP4.1
1) Copy the folder containing the models & name to whatever.
2) Click on File > Open.
3) Browse to the newly copied folder and select (highlight only) the top level assy.
4) Click References.
5) Click Select All.
6) Click Replace.
7) Fill in the Find what: (old W/O) and Replace with: (new W/O) fields, then click Replace All.
You should now have a complete assy & parts renamed to the new W/O.
NOTE: I cannot rememer if the drawings get updated using this method.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Thanks for the replies anyway.
Doesn't help you now...but something to look forward to.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
