How to invert curve dirrection ? V5
Curve goes one way ... Start to End... I Want the other way... Zero on one end.. Larger Value on the other end. You get the Idea
RE: How to invert curve dirrection ? V5
If you really need to reverse it you can use join curve - select the curve select the red direction arrow, select ok.
To avoid having duplicate geometry - turn on no keep mode
Derek
Derek
Inverting curves is especially helpful when you are creating templates, from which you will replace geometry and/or create macros from, and it needs to operate the same way with no intervention...
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
Are you using a Positioned Sketch for your PowerCopy? Where&How you orient the sketch might be the solution.
