Low spectral response value Ss yielding small seismic forces in Hawaii
Under the IBC 2003, seismic base shears are based on maximum considered earthquake ground motion for one-second and short spectral responses, S1 and Ss.  Typically in Southern California, Ss is on the order of 1.4.  In Hawaii the value is 0.178, resulting in a base shear of only 4% gravity. This seems ridiculously low.  Can anyone confirm a similar design value for a Hawaii job?
Many thanks.
RE: Low spectral response value Ss yielding small seismic forces in Hawaii
Depends where you are.  Ss values can be 2.67 near the active volcanoes on the island of Hawaii.  A value of 0.19 would apply at Barking Sands on Kauai.
Thank you.  I did a comparison to the UBC, which yields 6% gravity for the base shear.  I did not realize that parts of Hawaii had the equivalent of a UBC Zone 1 seismicity.
