Corrosion of 487-2C on production platform
I'm looking for reasons why a 487-2C material would corrode with only slightly lower Ni,Cr,Cu content than an adjacent item.  Both meet ASTM requirements for proper classification.  487-2C has no lower bounds for these alloying elements.  An item with .09Cr,.09Ni,.16Cu Wt% corroded within one week in a sweet crude environment, prior 487 item had a 20 year history.  A mill coating or machine fluid has been speculated, but no evidence.
RE: Corrosion of 487-2C on production platform
If the difference in behavior cannot be speculated, would it not be worth to launch a complete metallurgical investigation?
http://www.welding-advisers.com/
Small diferences in Cr may have an impact, but my money is on either microstructure (thermomechanical history) or surface condition.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
