Need equipment: "stud adapter" with 5/8"-11 and 1/2"-13 ends
I've been searching for a bit now through industrial suppliers with no results. I need a threaded steel stud that can connect to two different thread sizes on its opposite end (5/8"-11 to 1/2"-13). I've found connectors and couplers but I would prefer a single piece of rigid metal. Perhaps this is something that needs to be custom machined but I may as well ask. Any leads are appreciated, thanks.
RE: Need equipment: "stud adapter" with 5/8"-11 and 1/2"-13 ends
What material?
How many?
If it is small number your best bet is a local machine shop.
Nick
"Speed costs money boys, how fast do you want to go?"
If they can't thread a double ended stud you can get a 5/8-11 Class II 304/316 SS stud of the required length and turn one end down to 1/2-13.
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int./JCI
