Mechanical vs Structural Tubing
What is the difference between mechanical square tubing and structural square tubing? Both are A500 Grade B.
RE: Mechanical vs Structural Tubing
1.1 This specification covers cold-formed welded and seamless carbon steel round, square, rectangular, or special shape structural tubing for welded, riveted, or bolted construction of bridges and buildings, and for general structural purposes.
There are several ASTM Standard Specifications that contain deliberate wording for mechanical tubing.
This may help,
CODE
but if they carry the same spec then it may just be a naming error?? Many people/companies use the terms structural and mechanical interchangably.
Business Card http://mech.e.tripod.com
__________________________________________
Cycle Heaven.......www.tailofthedragon.com
Of course I forgot where I saw it, but it appears that some distributors offer tubing that would otherwise qualify to standard specifications as 'structural', because it is flawed in some way, e.g. the chemistry is off, or it would leak if used to hold fluid.
I.e., if tubing is offered at a substantial discount, without warranty or certs, as 'structural', you probably don't want to use it in an actual structure.
Mike Halloran
Pembroke Pines, FL, USA
