Hole Wizard center drills?
Does anyone know if Hole Wizard has center drills?
RE: Hole Wizard center drills?
Not directly, but you can very easily create them using the Countersink option and varying the parameters. I usually use one of the Legacy option selections and set the parameters there.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
alolesen,
I got tired of setting the parameters everytime as CorBlimey suggests so I created a Library Feature.  I created the file with configs so you can just select the size you need after inserting the Library Feature.  If you are using SW2005 or newer you can even change the size if you change your mind.
mncad
