Torx Fastener Design
Does anyone have a source for the technical specs. on the T15 Torx Head configuration for the teeth of the head?
RE: Torx Fastener Design
This information is documented in ISO 10664 Hexalobular internal driving feature for bolts and screws.  You can obtain this directly from ISO or from Global Engineering Documents:
http://www.iso.ch/
http://global.ihs.com/
Hey
You should find alot of info at these links.  If there is something you still need, post what it might be.
CODE
http://www.textronfasteningsystems.com/licensing/tncinch.html
http://www.textronfasteningsystems.com/licensing/tpncmetric.html
http://www.textronfasteningsystems.com/images/torx_plus/cad/torxplus.dxf  (DXF CAD)
http://www.textronfasteningsystems.com/PDFs/torx.pdf
http://www.textronfasteningsystems.com/products/torxplus/torxplusdata.html
http://www.semblex.com/products/licensed/DuroPT/pg5.cfm
Business Card     http://mech.e.tripod.com
__________________________________________
Cycle Heaven.......www.tailofthedragon.com
