Excel Contour Chart Axes
Hello all,
I am hoping that someone might know how to solve my Excel Contour chart issue. I am wondering if there is a way to change the ranges of the x and y axes on a Contour chart. I essentially want to zoom in on a portion of a chart based on calculated min and max range values. In certain instances I would want to set the max and min range values to non-integer values. So, having the ability to just change the display and not having to change my charted data would allow me to not have to interpolate between data points since my data points are charted at integer values.
RE: Excel Contour Chart Axes
good luck!
-pmover
I do appreciate the suggestion
He also gives a few nice links:
http://andypope.info/charts.htm
htt
Cheers,
Joerd
