Layer info AutoCAD 2004
I need some helpful advice on this one.  When I pick an object in AutoCAD 2004 it doesn't give me that objects info (ie. layer, linetype, etc.)  It just shows the current layer and settings.  I don't know what I would have done to make it do this.
Any ideas?
Brad
RE: Layer info AutoCAD 2004
Found the fix.  I guess I should have done some more searching before I posted.  FYI, the command that fixed it was PICKFIRST with the variable set to 1.
