*Importing material state and transferring results*
Hello everyone,
I am trying to transfer the material state at the end of a dynamic, explicit analysis (forming) to a standard static analysis (springback). I am using a modified drucker-prager cap model to account for the nonlinear effects. Is this possible? Also, if the static standard analysis is possible, after the springback i would like to extract the resonance frequencies in another step. However, the initial explicit analysis is axisymmetric as well as symmetric about the xz plane so I have only modeled 1/4 of the total blank. Is there a way to transfer these results to a full 3D model in order to extract the resonance frequencies correctly? Any help is greatly appreciated
Thanks again,
Chris
Thanks again,
Chris
