Access, Visual Basic and pdf-documents
Hi!
Can anyone help me with this?
I want to add a commandbutton to a form in Microsoft Access, that will open a pdf-file located at a specific place on our server. the name of the document is stored in a table.
Any VB-code for this?
RE: Access, Visual Basic and pdf-documents
Here is SOME of the code from a form I use to track documents. The table behind the form has a hyperlink field and document path field that supplies data to the hyperlinkaddress property of the command button.
Private Sub Form_Current()
On Error GoTo err_Form_Current
    If Me.Command119.hyperlinkaddress <> (Me.DocumentPath) Then ' updates hyperlink
    Me.Command119.hyperlinkaddress = (Me.DocumentPath)
    End If
    If DocumentPath Like "*jpg" Then
       Me!Picture.Picture = Me!DocumentPath
    ElseIf DocumentPath Like "*.bmp" Then
    Else: Me!Picture.Picture = ""
        Me.Command119.hyperlinkaddress = Me!DocumentPath '(Me.DocumentPath)
        Me.Repaint
    End If
If the document was an Image, It would show up in the form.
Maybe this will get you started.
Gerald Austin
Iuka, Mississippi
http://www.weldinginspectionsvcs.com
