Need Help to define 42CrMo4 HH TQ+T
Please provide a definition for the specification 42CrMo4 HH TQ+T. What does HH and TQ+T specifically means.
RE: Need Help to define 42CrMo4 HH TQ+T
Q + T means Quench and Temper.  This steel is strengthened by austenitizing (heating to ~ 1000 °C), then quenching (~ 25 °C), then tempering (~ 500 °C).
Cory
zner46,
You need to obtain the standard EN 10083-1 Quenched and tempered steels - Technical delivery conditions for special steels.  This standard defines the requirements for grade 42CrMo4 +HH +QT.  The +HH designation means that the grade has restricted hardenability (see Table 7), and as CoryPad already mentioned, the +QT means quenched and tempered.  Table 12 of this standard provides some guidance values for heat treating parameters, which for this grade are 820-860 C for the austenitizing temperature, and 540-680 C for the tempering temperature.  Oil or water can be used for quenching depending on the exact hardness, depth of hardening, etc.  DIN EN 10083-1 or BS EN 10083-1 are available from Global Engineering Documents using the following link:
http://global.ihs.com
These should clear up that pesky HH:
CODE
http://www.edelstahl-witten-krefeld.de/upload/binarydata_ewkinterd4cms/1556/7225_uk.pdf
http://www.edelstahl-witten-krefeld.de/upload/binarydata_ewkinterd4cms/1539/br_verguetungsst_thyrofort_en.pdf
http://www.novacciai.it/pdf/quenching_and_tempering.pdf
http://www.ovako.com/Data/r3116/v1/Data_sheet_Imatra_42CrMo4.pdf
http://alruqee.net/rtc_final/My%20Documents/RTC%20Web&CD/METAL_ALLOYS/low%20alloyed%20steel/4140.pdf
Business Card     http://mech.e.tripod.com
__________________________________________
Cycle Heaven.......www.tailofthedragon.com
