Block required - construction worker
Does anyone have an Autocad block of a man in a hard hat?
The type that is used to indicate scale on plant layouts etc. Front view would be best, but side view would do.
I thought they would be easy to find - but apparently not, little old men in flat caps with walking sticks are no problem, and there are lots of naked girls - can't really put them on a plant layout though!
Many thanks
RE: Block required - construction worker
Try here:
http://cben.net/
____________________
Acad2005, Terramodel
Thanks, but I had already found that site & they don't have what I need. Anyone else got any ideas?
I found a construction worker...
People > Elevation > Pg 13 > Workman.dwg
Missed the whole section that has them in!
Many thanks for your help lpseifert - much appreciated.
