dinamic update of feature while editing sketch
hi...
i'm more of a stylist right now so i was wondering if sw can handle this. so, is it possible to have whatever feature/feature tree update dynamicaly while editing sketches (without having to exit the sketch module so that whatever changes are taken into account)?
it's a bit of a chore to have to do this just to be able to judge the model aesthetically..
thank you
thank you
RE: dinamic update of feature while editing sketch
I think that is the closest SW can get to live rebuilds.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
well, i'm glad at least we can be happy with this faint pseudo live rebuilds :)
But besides if it doesn't do it, request it (ER).
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
so then? no workaround for this... thanks
"Or perhaps I do not understand your desire?"
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
When that option is toggled on, changes to the sketch update the I believe. I forget exactly how it works though....but I recall it giving some kind of dynamic update.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
Most of the ID guys here use surfaces because they are more "flexible" and better suited for "swoopy" stuff.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
htt
[quote]Finally for surfacing, and saving the best till last, is the Freeform Surface tool. This allows you to dynamically edit a surface using a push and pull, highly dynamic modelling workflow, and create highly complex forms that would typically be a nightmare to create in any modelling system, SolidWorks or otherwise.[/[quote]
http:
Jason
Jeff Mowry
