Need help! Plotting a 3d model of a robot arm workspace!
I trying to model the 3d workspace of the robot arm. Below is the matlab syntax. Px,Py,Pz is the goal position. q1,q2,q3 is joint angle limits. a1,a2,a3,d1 and d4 is link parameter.
a1=150;
a2=600;
a3=100;
d1=400;
d4=600;
q1=linspace(-170,170);
q2=linspace(-90,155);
q3=linspace(-170,190);
Px=(a1.*(cosd(q1)))+(a2.*((cosd(q1).*cosd(q2))-(sind(q1).*sind(q2))))+(a3.*((cosd(q1).*cosd(q2))-(sind(q1).*sind(q2))).*(cosd(q3)))+(d4.*(cosd(q1)).*((sind(q2).*cosd(q3))+(cosd(q2).*sind(q3))));
Py=(a1.*(sind(q1)))+(a2.*(sind(q1)).*(cosd(q2)))+(a3.*(sind(q1)).*((cosd(q2).*cosd(q3))-(sind(q2).*sind(q3))))+(d4.*(sind(q3)).*((sind(q1).*cosd(q2))+(cosd(q1).*sind(q2))));
Pz=(a2.*(sind(q2)))+(a3.*((sind(q2).*cosd(q3))+(cosd(q2).*sind(q3))))-(d4.*((cosd(q2).*cosd(q3))-(sind(q2).*sind(q3))))+d1;
Can anyone pls show me how to plot the Px,Py,Pz graph?
RE: Need help! Plotting a 3d model of a robot arm workspace!
You need to add bones and flesh to the 3d points that you have created. That is amazingly tiresome to do properly, you will need to add orientation points to each rigid body.
Then you could create a subroutine that can work out the screen coordinates of a given 3d location.
You will need to use similar triangles if you do it the way I did it.
Cheers
Greg Locock
Thanks for the tips! Do you have any example file of it?
No, I did it in Excel.
Cheers
Greg Locock
