Stress values for GLB (in wood layers near neutral axis)
I am trying to find out stress values (fb, fv) for those layers between top and bot. layers of a GLB. The reason is because I have this situation where the top layer (the strong one) of this cantilever GLB has to be cut (it hits the roof). This cantilever (5ft only) beam suports a point load (another beam)and now I have to check if it fails in shear and bending (because the top layer will be cut).
If I could have and idea as to how much the 2400psi and 195psi values reduce when the top layer is missing.
Beam is 8.75x48
Thanks.
M
Beam is 8.75x48
Thanks.
M
RE: Stress values for GLB (in wood layers near neutral axis)
http://www.unitstructures.com/
On that basis you can estimate an allowable stress. When taking this approach I try to be conservative to account for notch effects and other factors.
Thanks a lot.
M
