ATV Spring Rate
ATV Spring Rate
ATV Spring Rate
What is a common spring rate used on side by side ATV (like a Kawasaki Mule) with a swing arm rear suspension? The coilovers  I have are about 60 lb/in, and the rear tire weight is roughly 400 lb. I have plenty of room for spring placement. Any help is appreciated.
