Mate errors with flexible sub-assy's
I am having trouble mating a flexible sub assy into a higher level assy. The part is a simple spherical rod end that is constrained point-point at the center of the psherical ball. When this part is inserted into another assy and made flexible I can only apply one mate then it stops responding, it is still not fully contrained but no other mates will work. Has anyone else had similar troubles? Any suggestions?
Rawblyn
Rawblyn
RE: Mate errors with flexible sub-assy's
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Rawblyn
