Determining the Minimum of Three Numbers
I have three numbers in cells H28, H29 and H30.  I am trying to find the minimum of those three numbers.  I tried doing the formula below but it does not seem to work.  After talking to a co-worker he brought up the MIN function.  That also works, but I guess right now I am trying to figuere out why the function below is not working.  Appreciate if your help.  THANKS.
=IF((H28<H29)^(H28<H30),H28,IF(H29<H30,H29,H30))
RE: Determining the Minimum of Three Numbers
I'm not sure what you're trying to do with ^
The following will work to give the min of the three cells (assuming none are equal and you don't want to use min)
=+IF(H28<H29,IF(H28<H30,H28,H30),IF(H29<H30,H29,H30))
One possible result of your test is 0^0.  That is somewhat undefined. There was a discussion in the mechanical engineering other topics forum.
You should NEVER use Booleans in arithmetic expressions.
TTFN
I was trying to use the AND statement by using ^.  I have used this in mathcad, but I guess it does not work in excel, or is there another way I can use AND statement within and IF statement?
THANKS
The more structured way would be
=IF(AND((H28<H29),(H28<H30)),H28,IF(H29<H30,H29,H30))
Under peril of incurring uppercase wrath of other posters, I will mention (but not recommend) that you can also use "*" to accomplish boolena "and":
=IF(AND((H28<H29)*(H28<H30)),H28,IF(H29<H30,H29,H30))
Whoops. My last example had a * and an "and". I meant:
=IF((H28<H29)*(H28<H30),H28,IF(H29<H30,H29,H30))
"^" in Excel is an exponent, not an "and".
Hg
Eng-Tips policies:  FAQ731-376
gman1, HgTX got it right.
"^" is an exponent (raised to the power of).
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
THANKS, you guys have been very helpfull.
gman1
